Horn Adjustment screw tool? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    Is there a tool that anyone makes to fit the tone adjustment screws. In my case it is a 66. I finally got the screws to break loose using a vice grip. The screws are very stiff and I have used to penetrating oil, but they are still very stiff. I don't want to break anything.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • John R.
    • February 21, 2014
    • 38
    Re: Horn Adjustment screw tool?
    My question exactly. I'm rebuilding my 66 horns, they are flat, clean and in primer but that adjustment screw has a strange head that I can't name, and therefore I can't search for the proper tool. They are in such nice shape I hate to take a pair of vice grips to them. And vice grips aren't my style.
    Does anyone know what those screw heads are called and where a tool for adjusting them can be found?
    John
    • Keith B.
      • September 15, 2014
      • 1604
      been a while since I looked at it but if you try some 12 point sockets of different sizes I am sure you will find one that fits
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        The screw is seven point but I just tried a 1/4" 12 point socket. It barely fits over to the screw flange, but it turns if you push hard. I then tried my 12 pt tuneup 1/4" 12 pt and combination wrenches and those worked too.
        • John R.
          • February 21, 2014
          • 38
          Thanks guys. Those things hadn't moved in 50 years and I was unable to persuade them with a 12 point socket or wrench. I carefully used vice grips and they survived with only slight marks that I think the final painting will hide.
