67 regulator ground screw/star washer? - NCRS Discussion Boards
  • John S.
    • May 17, 2009
    • 164
    Should the 67 ground screw for the regulator have a star washer? Mine has screw with flat surface type area under the head. Should it also have a star washer under that?
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 67 regulator ground screw/star washer?
    John - I just double checked the ground wire at the regulator on our sb 67 & it does not have a separate star washer. The ground wire from the harness on our 67 is attached to one of the regulator mounting screws that has "lock washer like" surface on the underside of the washer feature of the mounting screw.
    I also looked at the 67 Corvette AIM & as far as I can see, the ground wire on the wiring harness is not long enough to go to the screw on the side of the regulator base as shown in UPC6, B4.
    Interesting.
    Pete
    • John S.
      • May 17, 2009
      • 164
      As I had suspected, another bogus deduct I got in judging! Thanks Pete, I could not find it either, but needed to check to be sure.
