C1 corvette steel wheels - NCRS Discussion Boards
  • Eric A.
    • December 21, 2012
    • 126
    Need guidance: I have a set of 5 steel original wheels. Just got them sand blaster but feel they may leak air because of the above average pitting. Does anyone have advice on a source who will restore these wheel? I feel this would be better than buying others. Open to any recommendations.
    thanks Eric
  • John F.
    • March 23, 2008
    • 2421
    Re: C1 corvette steel wheels
    I have had two sets sandblasted and powder coated. No leaks.
    • Steven B.
      • June 30, 1982
      • 4012
      Same as John. I have had a number sand blasted and never had a problem. You should not have to worry unless you have rust through.
      • Mike E.
        • February 28, 1975
        • 5141
        Are you concerned that it will leak along where the bead seats because of the pitting? A simple solution is to use tubes. Not judging-correct, but an option. Some will raise the concern about excessive heat because of the tube. That shouldn't be a problem unless you are driving some rather significant distances in pretty warm weather.
        • Terry D.
          • May 31, 1987
          • 2697
          Back in the day we would run a bead of chassis grease around the bead of the tire, seals those pesky leaks up everytime
          • Mike M.
            • May 31, 1974
            • 8408
            i use silicone dielectric grease if i fear a leak. also makes it easier dis-mounting in the future.mike
            • Eric A.
              • December 21, 2012
              • 126
              Should I put some type of metal filler in the pitting to make them look smoother on the powder coating. And if so does anyone recomend a good metal filler that can be sanded smooth and not affect the powder coating process.
              • Dan P.
                • December 1, 1990
                • 683
                There are a couple of products made to withstand the heat from powder coatings. Here is one http://www.alvinproducts.com/Products/Products.asp?id=1
                • Dennis C.
                  • June 30, 2002
                  • 888
                  Eric,
                  I used JB Weld to fill pitting holes in some rims I have restored. I filled the holes, let the epoxy dry and sanded them smooth. I sanded them up 600 grit using wet/dry sandpaper.
                  After sanding I had them powder coated. They have been holding air for 3 years now without a problem.
                  Dennis
