Passenger Side Mirror - NCRS Discussion Boards
  • Jim C.
    • April 1, 2006
    • 290
    I got into a Corvette discussion with a co-worker the other day, and somewhere along the line, we got on the topic of passenger side view mirrors. I was fairly certain that passenger side view mirrors were not factory installed until the mid to late 1970s. Although we've all seen right side mirrors on C1 and C2 Corvettes, I always thought those were dealer or previous owner installations. So, my question is, during what model year were FACTORY installed passenger/right side mirrors added to Corvettes? The other question might be this, during what year were passenger/right side mirrors at least a FACTORY option if they were not included as standard trim/safety equipment? I did do a search of the tech forum but couldn't find a definitive answer to either question. Thanks.
    Jim C.
    • 6948
    Re: Passenger Side Mirror
    Jim I believe that 73 was the first year for the pass. side outside mirror.
    • Jim C.
      • April 1, 2006
      • 290
      Thanks Edward. I sort of figured it was some where around then that the passenger side mirrors were factory installed.
      • Michael W.
        • April 1, 1997
        • 4290
        First year for factory installed side mirrors was 1977. Option RPO D35, dual sport mirrors at a cost of $36.00. 20,206 owners wisely chose them.
        These became standard equipment in 1980.
        Seems hard to believe that not all cars had a right hand side mirror.
        • Harmon C.
          • August 31, 1994
          • 3228
          Not 73 but about 77.
          Lyle
          • Francis F.
            • April 1, 1978
            • 420
            While were on the topic of R H mirrors,perhaps someone can settle a new discussion between me and the little lady.Our "66coupe" can be difficult to drive due to the blind spot on the RH due to the mirror missing,it has been said that a dealer installed in the day...The discussion always ends with ,IT'S NOT RIGHT,TAKES AWAY FROM THE ORIGINALITY,WILL CAUSE A DEDUCT OF POINTS @ JUDGING TIME!
            Can a member/judge/etc. comment for a final,To install or not to install that is the question ???
            FRANCIS
            • Reba W.
              • 938
              There is a minor deduction in the Exterior Section for the holes drilled in the door. The mirror itself does not get judged.
                • 15706
                Originally posted by Francis Ford (1888)
                While were on the topic of R H mirrors,perhaps someone can settle a new discussion between me and the little lady.Our "66coupe" can be difficult to drive due to the blind spot on the RH due to the mirror missing,it has been said that a dealer installed in the day...The discussion always ends with ,IT'S NOT RIGHT,TAKES AWAY FROM THE ORIGINALITY,WILL CAUSE A DEDUCT OF POINTS @ JUDGING TIME! Can a member/judge/etc. comment for a final,To install or not to install that is the question ??? FRANCIS
                I always set the inside mirror to pick up the RH side of the rear view, which includes the right rear quarter. The LH outside mirror has a wide field of view due to the short fender and rear deck, so it can be set to pick up the LH quarter and the center rear view.
                With the mirrors so set I have no significant blind spot. Try it out.
                Of course, I have a SWC, and according to some you can't see anything to the rear, but that's nonsense. IMO the rear window bar doesn't materially affect rear vision. A Convertible with the soft top up has a poorer right quarter view without a right side mirror than any C2 Coupe.
                • Don H.
                  Moderator
                  • June 16, 2009
                  • 2268
                  While were on the topic of R H mirrors,perhaps someone can settle a new discussion between me and the little lady.Our "66coupe" can be difficult to drive due to the blind spot on the RH due to the mirror missing,it has been said that a dealer installed in the day...The discussion always ends with , IT'S NOT RIGHT,TAKES AWAY FROM THE ORIGINALITY,WILL CAUSE A DEDUCT OF POINTS @ JUDGING TIME!
                  Can a member/judge/etc. comment for a final, To install or not to install that is the question ???
                  FRANCIS
                  Happy wife equals happy life. Install the mirror.......
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Unless 'the little lady' is the one to veto the installation.
                    • Francis F.
                      • April 1, 1978
                      • 420
                      YES SHE IS EXERCIZING HER VETO POWER ONCE AGAIN ! THANKS TO DUKE I WILL USE HIS METHOD , TO SEE BETTER.
                      I would not want the beatings so start again..
                      Francis,
                      • Steven B.
                        • June 30, 1982
                        • 3997
                        Correct. The mirrors were available FOR ORDER at the onset but a shortage soon happened. I ordered my '77 August 6, 1976 with sport mirrors and aluminum wheels. I got notification in October that my order was being held because the mirrors and wheels were out of stock. Some became available in later November.
                        • Paul Y.
                          • September 30, 1982
                          • 570
                          Well said Duke and the truth is finally out.
                          It's a good life!
