Re: Who had the pictures of the "HD" rear spindles?
I also did some further research on trailing arms (bare arms without spindle supports). I found that the small block trailing arms used from 1965 to 1977 were of GM #3864035, lh, and 3864036, rh. These arms did not have the holes for the rear stabilizer bar. They may also have been used on 1965-67 big blocks (with the St. Louis addition of the holes). The big block trailing arms were GM #3874769, lh, and 3874770, rh. These are the arms with the holes. The arms without the holes were replaced for SERVICE by the arms with the holes in November, 1965 but both sets of arms were used in PRODUCTION until 1977.
Since there were different part numbers for the arms with and without the holes, the trailing arm ASSEMBLIES (i.e. with bearing support, calipers, etc.) would also have had different part numbers with and without the holes even if the holes were the only difference.
