I am posting some pictures of the window regulators that were removed from my 1958 Corvette. One was a little rusty, so I cleaned and but some primer on it. The other one is galvanized. The bottom one has the number 68 stamped on the metal piece with the roller on the end. The short arm that pivots has 70 stamped on it and 65 is stamped on the longer arm that pivots. Also, as you can see, the area where the window crank goes on is recessed. My guess is the bottom one, which I believe is the drivers side, may be original. And the galvanized one may be a passenger car. I have searched the forum for pictures but have not found any. Does anyone know for sure?
