IMG_7269.jpgDoes anyone know how to remove the retention pin holding the two carb choke brackets together? The smaller bracket in the foreground attaches to the larger bracket with a pivoting rod held in place with that small pin. I thought it may be just pressed into the rod but it won't pull out. I need to replace the small bracket with the 68 only type and will keep the larger one. Thanks. Dale
