Lock washer or Not? - NCRS Discussion Boards
Lock washer or Not?
  • Rob M.
    • April 30, 2003
    • 657
    Lock washer or Not?
    On a 66 small block, the JG calls out a lock washer on the upper a-arm camber bolts. I don't see one in the AIM (UPC 3, A2) called out, it just calls out the nut.
    What is correct?
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Gary B.
    • February 1, 1997
    • 7018
    Re: Lock washer or Not?
    Rob,
    My July build date '66 has lock washers and thick (non-prevailing torque) nuts.
    Gary
    • Alan D.
      • January 1, 2005
      • 2038
      Rob, Remember the AIM does not list each component of a sub-assembly, only those additional parts required to assemble the car on the line.
      Similar questions keep popping up and the pro's clarify. These details however seem to be deep into a thread and not easy to find, just keep asking.
      Know I continue to learn each day.
      • Michael H.
        • January 29, 2008
        • 7477
        What is correct?
        Rob
        Early production 66 cars had a lock washer and hi-nut. For later 66 cars, the lock washers and hi-nuts were replaced with a self locking nut. I don't know exactly when the change occurred on the line.
        • Gary B.
          • February 1, 1997
          • 7018
          Originally posted by Michael Hanson (4067)
          Rob
          Michael,
          I strongly believe the lock washers and hi-nuts on my July 21 build date '66 (VIN 26xxx) are original. If the change to the self-locking nut happened in late '66, it was very late, or there was overlap during which time both hi-nuts and self-locking were used.
          Gary
          • Michael H.
            • January 29, 2008
            • 7477
            Originally posted by Gary Beaupre (28818)
            Michael,
            Gary
            Gary
            I don't know when the change occurred but I always assumed it was late in production.
            The 66 AIM is no help as it shows the new design bolt and self locking nut with no record of change.
            • Tony S.
              NCRS Vice President, Director Region VII & 10
              • April 30, 1981
              • 988
              Correct me if I'm wrong, but I have been under the impression that the lock nut began with the '67 model?
              Tony
              Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
              Original member of the Kansas City Chapter, est'd 07/11/1982.
              Member: 1965 and 1966 National Judging Teams
              Judging Chairman--Kansas City Chapter.
              Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
              • Matt L.
                • February 23, 2010
                • 337
                hi guys, here are a couple pics from two very original cars. the first pic is from my VIN 19,XXX. The second pic is from VIN 7XXX. they both the nut with lock washer. i hope this helps.
                take care,
                Matt66 vette exhaust clamps 1173.jpgelios 66 corvette 425 12,000 mile 320.jpg
                • Gary B.
                  • February 1, 1997
                  • 7018
                  take care,
                  Matt[ATTACH=CONFIG]49148[/ATTACH][ATTACH=CONFIG]49149[/ATTACH]
                  Matt,
                  The nuts and washers in your photos look exactly like the ones on my 26xxx VIN '66.
                  Gary
                  • Rob M.
                    • April 30, 2003
                    • 657
                    Gary,
                    My car had the lock washer and nuts just like Matt's photo when I pulled them off. But, when I checked the AIM, I assumed someone had added them at some point in the past. I will put them back on the car. Thanks for all the help.
                    Regards
                    Rob
                    '08 6 speed coupe
                    • Gary B.
                      • February 1, 1997
                      • 7018
                      Gary,
                      Regards
                      Rob,
                      About what VIN is your '66? Is it close to mine?
                      Gary
                      • Timothy B.
                        • April 30, 1983
                        • 5186
                        FWIW, my 67 is a B-23 (September 23) build and it has the lock nut.
                        • Alan D.
                          • January 1, 2005
                          • 2038
                          Ahhh, mis understood which lock washer we were discussing sorry
                          • Rob M.
                            • April 30, 2003
                            • 657
                            May 6 build Gary
                            Rob
                            '08 6 speed coupe
                            • Gary B.
                              • February 1, 1997
                              • 7018
                              Rob,
                              Until someone shows me some examples of original '66s with the self-locking nut, I'm going to assume that the use of the hi-nut and lock washer continued thru the end of the '66 model year. Given the July 20 build date of my '66, it seems like the combination of the nut and lock washer was used at least up until the last week or two of '66 production.
                              Gary
