Routing of 67 front crossover brake line - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 1995
    The attached picture shows how I routed my front brake crossover line with the clamp screws below the line. It seems to fit OK, but the original line of my 70 Corvette is mounted with the clamp screws above the line. Do I have it on correctly?IMG_0993.jpg
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: Routing of 67 front crossover brake line
    You have the line and clamps correct. The washers and bolts on the "A" arms should be black.
      • 43219
      Originally posted by Patrick Boyd (9110)
      The attached picture shows how I routed my front brake crossover line with the clamp screws below the line. It seems to fit OK, but the original line of my 70 Corvette is mounted with the clamp screws above the line. Do I have it on correctly?[ATTACH=CONFIG]49085[/ATTACH]
      Patrick-----
      1969 has the clamps and bolts above the line, too. So, I expect the change was made for C3 (although I do not know about 1968).
      • Page C.
        • February 1, 1979
        • 802
        Agree with both of Stephen L. answers.
        • Patrick B.
          • August 31, 1985
          • 1995
          Thanks for the help. Are the washers and bolts painted or phosphated?
            • 43219
            Patrick------
            Painted with the arms.
            • Stephen L.
              • May 31, 1984
              • 3156
              The bushings behind the washers should also be black.......
