64 & 67 proper caulk for door vapor barriers - NCRS Discussion Boards
  • James B.
    • December 1, 1992
    • 281
    I am taking apart my very original 67 and starting restoration. Also have door panels off my 64 to repair door opening mechanisms. The 67 has a white caulk with a string in it around the perimeter of the vapor barrier. I have new paper barriers for the 64 and want to attach with a caulking as close to original as possible. Can anyone recommend a product/source?
    Also, the 67 exterior color is Ermine White and the caulk was white. I assume they used white on all cars and didn't match the caulk with the exterior color. What color is appropriate for the 64?
    Lastly, on the '67 all openings in the inner fiberglass door skin were covered with a black tape and all screw heads had a black asphalt like caulk covering them. Was the 64 done the same way?
    Will appreciate any help/advise, Thanks, Jim B
    • 6950
    Re: 64 & 67 proper caulk for door vapor barriers
    Jim, There was a post a few days ago on this subject and the poster found some white string caulk at the local ace hardware store. cannot help on the black tape and blk. covering subject not really sure what your referring to.3M Does make a black strip caulking if that's what is on the screw heads.
    • Alan D.
      • January 1, 2005
      • 2046
      Also see thread; 1966 Inner Door Panel Black Out
