63 Rocker Panel screws finish - NCRS Discussion Boards
    • 6950
    I have some mixed results of what the finish on the screws that retain the lowers rocker panels. Maybe some of you 63 guys can tell me which finish belongs on them. or what you judges like to see.
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 63 Rocker Panel screws finish
    Cad finish
      • 6950
      Harry, did either of your 63's have a black finish, I have seen some 63' s with black -- original ???
      • Michael H.
        • January 29, 2008
        • 7477
        Would these be the 5/16" hex head with integral washer?
          • 6950
          Yes Mike that is the screws configuration.
          • Michael H.
            • January 29, 2008
            • 7477
            Ed
            I just looked at the original print. Harry is correct. The finish is supposed to be cadmium.
            Poor memory but wasn't there two different design screws used for 63? One for early cars and the 3830604 for later cars?
              • 6950
              Mike the only thing that I know that different was the earlier cars had 4 Philips head screws that retain the sides,2 front and 2 on the rear sides of the rockers. the later used just two screws, one at each end.
              • John D.
                • December 1, 1979
                • 5507
                Edward, There are two variations of those Sems screws. Some with a circle around the logo and some plain. As I mentioned in an older post my 63 has had those screws replated several times. My 63 has had those screws replated several times. Black, cad and back and forth. John
                • Alan D.
                  • January 1, 2005
                  • 2046
                  Michael the 3830604 is the same used for 1964. In the past have had the same question on finish.
                  My original SEMS are black, Mar64. A number of people have reported that their originals were also black. A search in Noland's book shows a mix
                  At one time LIC said they had a print showing the finish to be black, however I've seen your print with the call for cad.
                  So - bottom line Who Knows, not me. (I just left mine as is)
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    I suppose it could be black cadmium but it doesn't specify. I don't have any info on the 4341-M spec.
                    I just looked at the original GM print for 3830604 again. It states;
                    Cadmium plate GM 4341-M
                    Finish to be as taken from plating bath.
                    • Joe R.
                      • July 31, 1976
                      • 4551
                      Michael,
                      I've taken several 63's and 64's apart thru the years. (destroyed a couple) Have never seen any cad plated screws or even a trace of cad plating on any. All seem to be (rust) black phosphate. Does not the spec from GM specify the minimum spec for screws, bolts, nuts etc.? Could it be that GM or some nut case thought black phosphate to be a superior finish than the mil spec 4341-M??
                      JR
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Originally posted by Joe Ray (1011)
                        Michael,
                        JR
                        JR
                        It's possible that the screws are black cadmium. (yes, there is such a thing)
                        • John D.
                          • December 1, 1979
                          • 5507
                          After a part is cadmium plated it's a simple process to have it chromated. Chromate comes in various colors. One of the colors is black.
                          Maybe they did that in the old days when cadmium was readily available and popular due to it's ability to withstand the elements better than zinc.
                          But today if you asked for black cad you would probably end up getting black zinc.
                          Black zinc is far superior to black phosphate you know. Trouble is at first the black zinc is a tad too shiny. But after a while it tones down.
                          I will ask my plater if he does black cadmium.
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Originally posted by John DeGregory (2855)
                            After a part is cadmium plated it's a simple process to have it chromated. Chromate comes in various colors. One of the colors is black. Maybe they did that in the old days when cadmium was readily available and popular due to it's ability to withstand the elements better than zinc.But today if you asked for black cad you would probably end up getting black zinc.Black zinc is far superior to black phosphate you know. Trouble is at first the black zinc is a tad too shiny. But after a while it tones down.I will ask my plater if he does black cadmium.
                            JD
                            You are correct. (first time) I just looked it up and the various colors come from a conversion coating over the cadmium. Here's a link.
                            http://www.chemprocessing.com/finishes/cadmium-plating.html
