62 Corvette Turn Signal Flashers - NCRS Discussion Boards
  • Peter L.
    • May 31, 1983
    • 1930
    C2 Gurus - Which turn signal flashers are acceptable for NCRS Judging on 1962 Corvettes. Thanks, Pete
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 62 Corvette Turn Signal Flashers
    Opps C1 Gurus
    • David L.
      • July 31, 1980
      • 3310
      Pete,
      I am not a C1 Guru but this is what I have to offer which your probably already know:
      The 1962 Corvette AIM lists GM # 3758682 and 3758683 as the flasher part numbers in Sect. 12, sheet 12.00.
      My 1963 Chevrolet Parts Catalog (Oct. 1962) lists GM # 3758682 for 61-63 Corvettes as well as other Chevrolet models. The description is "FLASHER, controls 3 bulbs only (AP373V). The AP373V is a Tung-Sol flasher.
      What is confusing is that Chevrolet sold the Tung-Sol AP373V, Signal Stat 143, and Signal Stat ZN332 in GM boxes with the 3758682 part number.
      Back in the 1980's I found a Tung-Sol AP373V flasher (also stamped "H 362") in a 1962 Chevrolet Impala. As you know I have had many NOS AP373V flashers and I (or anyone else) have yet to figure out the date code system (if one exists) on these flashers ("H362", H119", "H661", "H862", H681", etc.).
      Dave
      • Peter L.
        • May 31, 1983
        • 1930
        Dave - Thanks. I have some Tung-Sol AP373V in a box labeled 1961-1963 but I wasn't sure if they were used in both Chevrolets & Corvettes. I guess I need to label things better. Pete
        • David L.
          • July 31, 1980
          • 3310
          Pete,
          Many years ago I researched the 3758682 flasher (Tung Sol AP373V) in the 59, 60, 61, 62, 63, 64, 65, 66 and 67 Chevrolet parts catalogs and found the following:
          59 PASS
          60 IMPALA, NOMAD
          61-62 IMPALA (exc. S.W.)
          61-63 CORVETTE
          63 IMPALA
          I have since sold my 55, 56, 58, 59, 60, 61, and 62 Chevrolet parts catalogs.
          Dave
          • John F.
            • March 23, 2008
            • 2415
            I have the ZN332 in my 62.
            • Peter L.
              • May 31, 1983
              • 1930
              John - Thanks. That's the Signal-Stat 3-lamp flasher, it appears that the Tung-Sol 3-lamp flasher equivalent would be the AP373V. Pete
              • David L.
                • July 31, 1980
                • 3310
                John,
                There should be a date code stamped on your ZN332 flasher.
                Example: "S2562" (Syracuse, 25th week of 1962).
                Dave
