63 frame restoration - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 265
    just finished having the frame blasted. What does everyone recommend as far as the inside of the frame goes. Years ago I used a rust inhibitor, but today there are some new things on the market,IE rust converters which I have used on other metal projects with very good success.
    Also what is the best way to finsh the frame ? Someone recommended 2 coats of epoxy primer and then a good semi gloss
  • Douglas C.
    • September 30, 1988
    • 237
    Re: 63 frame restoration
    Robert,
    Eastwood makes a paint/rust inhibitor with a special spray hose that can be pulled through your frame rails while it coats the interior.
    I would try to get as much sand out of the rails as possible prior to treating with inhibitor.
    --Doug
