69 power steering cap - NCRS Discussion Boards
  • Paul K.
    • February 1, 2002
    • 160
    I have a black metal cap with a round plastic dipstick, is it suppose to have a vent hole? The repro caps do not have this hole, So which is correct? Paul klemetson
    • 43219
    Re: 69 power steering cap
    Paul------
    I don't know, for sure, if what appears to be a hole is actually a vent hole. Nevertheless, what you describe sounds correct. A photo would be most helpful in confirming this.
    Be advised that 1969 was a "change-over" year for the power steering reservoir cap. Early cars had the cap with the round, metal cap. Later cars had a cap with a "scalloped" perimeter and which was plastic.
    • Paul K.
      • February 1, 2002
      • 160
      Joe --- does the cap need a vent hole, or will the plastic cap with no vent hole work? Paul klemetson
        • 43219
        Paul-----
        According to GM, the plastic cap with scalloped perimeter will SERVICE all applications originally using the steel cap. Assuming that the hole in the steel cap is actually a vent, then some sort of "non-hole" venting mechanism is apparently built into the plastic cap.
        • Paul K.
          • February 1, 2002
          • 160
          Thanks Joe
          • Michael C.
            • January 9, 2013
            • 332
            Paul,
            I've attached photos of my late 69 plastic cap. The vent hole goes through cap and tube.
            Mike
            • Greg L.
              • March 1, 2006
              • 2291
              I'm curious what is considered early and late in regards to this cap.
              My Jan 31st car has the plastic cap and has been that way since I bought it in 88. I always assumed it was original given the condition of the car when I bought it but I'm now curious to see what you guys think.
              • Jeffrey S.
                • May 31, 1988
                • 1882
                My Oct. '68 car has the same cap as shown.
                Jeff
                  • 43219
                  Originally posted by Michael Carl (57885)
                  Paul,
                  Mike
                  Mike-----
                  Interesting. The late 1969 cap was GM #7803820. This part number was used from 1969 through early 1982. However, it apparently changed at least once and possibly several times over the years. All of the examples of it I have ever noted did not have a hole in the center. Instead, they usually have a blank, round "nub". They also have the additional raised lettering "DO NOT OVERFILL". Otherwise, they are similar to the cap you show.
                  The GM #7803820 was discontinued from SERVICE in March, 1982 and replaced by GM #7834183.
                    • 43219
                    Jeff
                    Jeff-----
                    That's also interesting. I have a friend that's the originl owner of his October, 1968-built 1969. His car has the stamped steel cap.
