72 vacuum hose grommets - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    Where can I get a replacement for the large (1 5/8") rubber plug (?) that traverses the firewall with two 1/4" OD hoses, one black the other black with a green stripe. The 1-5/8 hole 45 deg. angles toward the passenger side of the vehicle. Can I find a replacement or do I have to cleanup my original ? I plan to enlarge the tube holes through the plug as I an using larger than original vacuum hoses.
    Rey Stenhouse 26007
    1972 LS-502 Coupe
    • 43248
    Re: 72 vacumn hoses
    Rey Stenhouse 26007
    1972 LS-502 Coupe
    Rey-----
    They're called GROMMETS. Dr. Rebuild has just about every one of these that was ever used on a Corvette.
    • Rey S.
      • April 1, 1995
      • 277
      Re: 72 vacumn hoses
      Thanks Joe
      • Graeme B.
        • October 23, 2007
        • 213
        Re: 72 vacumn hoses
        The Doc. has the correct hoses as well.
