Differential broken ear - NCRS Discussion Boards
  • Tim G.
    • March 1, 1990
    • 1390
    Is it possible to repair the broken ear on a 1967 differential? A car I purchased has only three bolts holding the rear spring in place due to the missing ear. I don't have the broken off piece and it's the original differential. I know it needs to come out, has anyone had luck repairing these?
  • Mike M.
    • May 31, 1974
    • 8400
    Re: Differential broken ear
    you'll need another COVER. the rest of the cneter section is ok. either used at swap meets or a repo(which is discerable from an orinal cover.mike
    • Michael H.
      • December 1, 1987
      • 730
      Purchase another cover, used if you can find one. There will be a part number and a casting date on the cover, get the same part number.
      • Jim T.
        • March 1, 1993
        • 5351
        Paragon might have a cover since they sell used parts for Corvettes as well as new parts.
          • 43248
          Tim------
          I agree with the other responders; get a another cover. For one thing, if you don't have the broken-off piece, it will be virtually impossible to fix the cover. For another thing, welding gray cast iron is problematic no matter what anyone says.
          On top of everything else, these covers are not rare. A lot of Corvettes have gone to "Corvette-heaven" and left their covers behind. The same cover was used from 1965 to 1979 although the covers are dated.
          Pat Ikerd at Ikerd's Corvette in Bedford, IN usually has hundreds of these covers. Make sure you get one that is clean and doesn't have corrosion-caused "pock-marking". To me, a clean, non "pock-marked" cover would be more important than a date-correct one.
          • Wayne M.
            • March 1, 1980
            • 6414
            The same cover was used from 1965 to 1979 although the covers are dated. .....To me, a clean, non "pock-marked" cover would be more important than a date-correct one.
            What's the consensus on dating of the ..375 cast # covers ? I haven't seen many, but IMO, cast dates didn't start before early calendar 1969, or maybe mid-1968.
            What do the TIM&JG's say ?
            • Gary R.
              • April 1, 1989
              • 1799
              As the others mention just replace the cover. I would use a Muskegon HD cover over a stock cover myself.
              • Tony S.
                NCRS Vice President, Director Region VII & 10
                • April 30, 1981
                • 990
                Wayne, you may be right, but when it comes to judging it's tough to see either way.
                Tony
                Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                Original member of the Kansas City Chapter, est'd 07/11/1982.
                Member: 1965 and 1966 National Judging Teams
                Judging Chairman--Kansas City Chapter.
                Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                • Joe R.
                  • July 31, 1976
                  • 4551
                  My two cents! Me thinks that a replacement cover and my safety is more important than any date correct cover alive! Think about going down the Interstate at 70-80MPH and the other cover bolt drops on the pavement. That would be the ride of your life. Maybe the last!
                  JR
                  • Steve L.
                    • June 30, 2001
                    • 763
                    My ear was broken unknown to me. Also one of the bolts were broken. When I took the rear end apart, I found the main spring was broken in half right in the middle of the diff. I must have driven like that for a long time because the jagged edges of the spring were smoothed out. I shiver every time I think of it. I think it all started when a dealer replaced my strut rod that they bend by lifting the car by the strut rod. They probably torqued it down to spec while still on the lift.
                    Steve L
                    73 coupe since new
                    Capital Corvette Club
                    Ottawa, Canada
                    • Chuck G.
                      • May 31, 1982
                      • 2036
                      Here's what you're looking for. This one is dated for an early 63.
                      • Patrick B.
                        • August 31, 1985
                        • 2003
                        http://www.ebay.com/itm/Corvette-Ori...p2056016.l4276
                        Look at the "also viewed" items in this ebay ad. You can buy one with a pre-broken ear for only $44.99. What a deal!
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          LOL! One man's junk is another man's treasure???
                          • Chuck G.
                            • May 31, 1982
                            • 2036
                            Maybe Tim, our original poster, could get a "core credit" of $44.99 by sending his broken one in when he buys a good used one.
                            Chuck
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              The eBay one must be for an early 1973, as 1963, 64 and early '65 rear diff covers were cast # 3830303. Note no cast date by the filler plug.
