C3 vacuum actuator filter - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    Do you know what you can make a vacuum actuator filter out of? It's the foam filter which most originals have deteriorated. Not sure if I have named correctly. Thanks.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Edward B.
    • March 29, 2013
    • 691
    Re: C3 vacuum actuator filter
    Bill, are you referring to the Windshield Wiper door solenoid attached to the back of the tachometer? (See attached)
    If so, go down to your local hobby or crafts store and get some "open cell" foam. It's what was originally used.
    Ed
    • William H.
      • January 1, 2006
      • 209
      It would be the headlight/wiper door actuator relay valve filter. Is that the same filter material?
      Bill Hyndman
      • Edward B.
        • March 29, 2013
        • 691
        Ah, so this...
        Yep, same stuff.
        Ed
        • Don L.
          • August 31, 2005
          • 1005
          Tip: when you cut the foam to size, cut it full enough so that the interference fit holds it in place or put a tiny drop of contact cement on it to hold it in place. It needs to be bigger than you might think, Don't ask me how I know .
          Don Lowe
          NCRS #44382
          Carolinas Chapter
