Ignition switch wiring - NCRS Discussion Boards
  • Steve V.
    • June 27, 2011
    • 95
    I am installing a new wiring harness in my 1960. There are two pink wires going to the ignition switch. One is 14 ga. the other 16 ga. I can't tell by the wiring diagram which goes where. Please enlighten me.
    Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
  • Donald H.
    • November 2, 2009
    • 2594
    Re: Ignition switch wiring
    Try searching this forum and you can find at least one (see below). I recall a better picture in a response than the one in the link below, but this one will work. Also, if you are wiring you C1 and have never done it before, I would strongly suggest you get the illustrated wiring diagrams from Dr. Rebuild.
    https://www.forums.ncrs.org/showthre...gnition+switch
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Donald H.
      • November 2, 2009
      • 2594
      here's the other document
      1960 Ign Sw Wiring.pdf
      Don Harris
      • Steve V.
        • June 27, 2011
        • 95
        Thanks Donald,
        Who's Dr. Rebuild?
        Steve
        Thomas Edison
        • Terry D.
          • May 31, 1987
          • 2698
          Dr. Rebuild is a Corvette vendor, but you could have googled it and found that out.
          • Steve V.
            • June 27, 2011
            • 95
            Steve
            Thomas Edison
            • Philip P.
              • February 28, 2011
              • 558
              I have a copy in .pdf of the wiring diagram that may help if you want to e-mail me I will send it.
              pkporter@q.com
              Phil
