K-19 Smog - NCRS Discussion Boards
K-19 Smog
  • Dale S.
    • November 12, 2007
    • 1224
    K-19 Smog
    After driving my 1967 K19 smog car( 327), all of a sudden it starts back firing out thur the right exhaust, lightkly on deacceleration and loud on full throttle. I took the atr pump belt off and it stopped. any ideas. I know there are not many of the 1966 and 1967 csrsd out here. dale
    • 43211
    Re: K-19 Smog
    Dale-----
    Very possibly a failed mixture control valve (the 66-67 term for what later became known as the diverter valve).
      Re: K-19 Smog
      Dale-----
      I agree - when the diaphragm in the mixture control valve (or in the diverter valve) fails, the valve defaults to wide open, so the A.I.R. pump outputs constantly to the air manifolds (and into the exhaust manifolds); normally on over-run (high vacuum) the valve closes and dumps the pump output. When it pumps constantly with a failed diaphragm, significant backfiring (actually after-firing) is quite common.
        • 43211
        Re: K-19 Smog
        Dale------
        If you do need a mixture control valve, good luck trying to find an NOS example. And, if you do find one, it'll likely take a lot of "long green" to buy it. However, Bill Hodel may be able to rebuild your valve.
        • Gerard F.
          • June 30, 2004
          • 3805
          Re: K-19 Smog
          Dale,
          Here's how your K-19 valves looked like when I re-plated them in 2006:
          I think the diaphragms in these valves were already shot when I re-plated them.
          They look good but maybe see what you can do with the innards.
          Jerry Fuccillo
            • 43211
            Re: K-19 Smog
            Originally posted by Gerard Fuccillo (42179)
            Dale,
            Jerry------
            These are the back-flow prevention valves. They should be checked but they are unlikely to be the direct cause the sort of problem Dale is experiencing. However, they could be the underlying source of the problem. If one of these valves fail, it allows hot exhaust gasses to flow back into the mixture control valve and the AIR pump. This will destroy the mixture control valve and pump in short order.
            The back-flow valves can be easily checked. Just blow into each end. You should not be able to blow any air into the threaded end. If you can, the valve is junk and must not be used in an operating AIR system.
            • Ara G.
              • January 31, 2008
              • 1108
              Re: K-19 Smog
              Dale------
              Dale, I have a few mixture control valves, and it won't take a lot of green to get one...we can negotiate with beer....PM me....I have 3 more smog cars to give to you in order to update your smog registry also....ARA
              • Dale S.
                • November 12, 2007
                • 1224
                Re: K-19 Smog
                Thank you gentleman, I will try the recommended tests on the diverter valve and the anti back fire valves. Ara thank you for your offer, I will let you know what I find. This is the first time it has not worked in 46 + years. John H. I have lost your Email address could I have it again? Ara, I would like to add the K-19 cars to my list, you can email it to me. That would make 43, 1966 and 1967 K-19 cars as I remember. I see some K-19 cars on some of the TV auctions, but dont know if they are on my list or not. My list has not been given to ANYONE. Thank you again Dale
                • Dale S.
                  • November 12, 2007
                  • 1224
                  Re: K-19 Smog
                  Doug Lee, Thank you for your email. I printed it out and will use it. Again thanks Dale
