1968 back up light grounding? - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 210
    My 68 back up lights stopped working and I think it's a grounding problem. On the drivers side back up light 2 pair wires, there is a grounding clip on one of the wires but I don't know what it connects to. The other side does not have this clip. Thanks if you can provide guidance.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Jeff P.
    • October 21, 2011
    • 287
    Re: 1968 back up light grounding?
    Bill---- I look on page H273 in the Assy Manual and see the wire you refer to. I see that wire connecting to the inside driver side frame rail. Does yours connect there ?
    • William H.
      • January 1, 2006
      • 210
      Jeff. Thanks, I see what you are referring to. I will check and see if that ground is there. I'm wondering if the original ground went bad and someone tried to add a new one by way of a clamp/splice. Much appreciated.
      Bill Hyndman
