C1 Jack Handle Spoon End - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    As you jack equipment gurus probably know, the GM drawing for the 53-60 jack handle do not call for a spoon shaped end. But apparently that's what the manufacturer made as the JG calls it out as a key feature.
    The photos I've seen of the "spoon end" in the JG really aren't that great and I'd like to see a good close up in focus so I know what to look for and can help identify the repro from the original.
    Anyone have a good photo to share?
  • David S.
    • December 1, 1982
    • 310
    Re: C1 Jack Handle Spoon End
    DSC01474A.jpgTroy how does this work for you Dave
    • Troy P.
      • February 1, 1989
      • 1284
      Very good, Dave. Do you happen to have a shot of the other side?
      • Tom P.
        • April 1, 1980
        • 1830
        That looks EXACTLY like what came with my 56 when I bought it in 73!
        To the BEST OF MY KNOWLEDGE (key words: BEST OF MY KNOWLEDGE) the jack and handle that are in the car now are the ones that were placed in it at the St. Louis assembly line.
        • David S.
          • December 1, 1982
          • 310
          Troy I will get you a better shot later today Dave
          • David S.
            • December 1, 1982
            • 310
            DSC09912.jpgDSC09913.jpgDSC09914.jpgDSC09916.jpgTroy I am sending the pictures you requested. I have also sent pictures of the rivet that holds the two piece handle together. If you or anyone else would like more picture or pictures of the jack or lug wrench contact me on my regular email and I will get them out to you. In the subject line use NCRS & Jack dasm5657@yahoo.com
            • David S.
              • December 1, 1982
              • 310
              I had to do a separate post to add the rivet.
              • Troy P.
                • February 1, 1989
                • 1284
                Wonderful! Doesn't get better than that. Thanks for your help.
                Now if we only knew what the intent of the spoon end was. The end shown in the GM drawing, which was more of a right angle, would have worked better. My 56 Chevy truck had the right angled end and it was handy to lock into the slot on the jack to drag the jack around under the truck to get aligned with the chassis rail. Don't think we'll be dragging around C1 jacks though.
                • Mike E.
                  • February 28, 1975
                  • 5153
                  62 C1 jacks o have a right angle. also coarse thread, also a coarse thread shaft that made the car harder and quicker to lift, and a welded-on base that was prone to removing itself rom the jack when used. Probably was 20 cents cheaper to produce. it as not a better jack, in spite o the 90-degree end on the handle. That might have been the only improvement.
