67 L79 327/350 HP engine was rebuilt approximately 18 months ago. Noticed last week a consistent noise from the timing chain area that is directly proportionate to the RPM's. The noise appears to be the timing chain or gear slightly contacting the block or timing gear cover. The noise goes away completely once the clutch pedal is slightly depressed enough for the through out bearing to make initial contact. Using a scope I could detect the noise from the timing gear area while the bell housing was quiet and I believe eliminating the through out bearing as the culprit. The only component which has not been replaced to my knowledge is the harmonic balancer. With the clutch fully depressed the engine sounds perfect at 3000 rpm. Duke Williams and the machinist have questioned the possibility of failed thrust bearings allowing the crank to move excessively so that the timing chain or harmonic balancer come in contact with the cover, curing itself when the crank move forwards once the clutch pedal is slightly depressed. The balancer may be failing but I'm not sure if it would cause this issue. The machinist suggested dropping the oil pan to inspect the crank for excessive movement. I would appreciate any comments if anyone else had ever experienced a similar issue. Thanks John Cianciolo (9728)
