C2 Fan Clutch - NCRS Discussion Boards
C2 Fan Clutch
  • Donald H.
    • November 2, 2009
    • 2586
    C2 Fan Clutch
    Is there a way to tell from a picture if a fan clutch is correct for a 66 small block car? I know per the TIM&JG that it should measure 1.8" end of the shaft flange to the boss where the mounting studs are. I'm looking for one and there is one on ebay now that says it is for small block.
    Here is one on Ebay: http://www.ebay.com/itm/corvette-fan...ea48a1&vxp=mtr
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • David L.
    • July 31, 1980
    • 3310
    Re: C2 Fan Clutch
    Don,
    The fan clutch that is on your Ebay link is the style used starting about 1969 or so. I believe that is made by Eaton.
    Enclosed is a photo of one of the types of fan clutch (made by Eaton) used in 1966 and 1967.
    I may have a photo of my original Schwitzer fan clutch dated Feb. 1966 which has the bar strip on the front face.
    Dave
    • Donald H.
      • November 2, 2009
      • 2586
      Re: C2 Fan Clutch
      I hate to be dense, but is there a difference in the faces between your pictures and the one on EBay?
      Don
      Don Harris
      • Stephen L.
        • May 31, 1984
        • 3162
        Re: C2 Fan Clutch
        Look at the difference in the raised "tabs" on the face. The one on Ebay has an "angled" tab while David's are "rectangular"
        • Donald H.
          • November 2, 2009
          • 2586
          Re: C2 Fan Clutch
          Ah, thanks, now I know what to look for!!!
          Don Harris
          • Harry S.
            • July 31, 2002
            • 5330
            Re: C2 Fan Clutch
            I believe David is spot on. Look for one with the small oil reservoir like his picture.
            • Larry M.
              • January 1, 1992
              • 2701
              Re: C2 Fan Clutch
              Original Eaton fan clutches are also identified/dated with ink stamp. Archives has the date codes. I can also provide if needed.
              Larry
              • David L.
                • July 31, 1980
                • 3310
                Re: C2 Fan Clutch
                I just bought the Eaton fan clutch (as shown in the photo below) today at a swap meet in Thompson, CT. It is an Eaton style fan clutch dated "E11F" (May 11, 1966).
                Dave
                • Donald H.
                  • November 2, 2009
                  • 2586
                  Re: C2 Fan Clutch
                  I need to follow you around at swap meets!!
                  Don Harris
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Re: C2 Fan Clutch
                    You need to be slightly ahead of him at swap meets.
                    • Donald H.
                      • November 2, 2009
                      • 2586
                      Re: C2 Fan Clutch
                      True, what you said!!!
                      Don Harris
                      • Donald H.
                        • November 2, 2009
                        • 2586
                        Re: C2 Fan Clutch
                        I found another one on Ebay that is listed as a 61 fan clutch. No apparent stamping on the face. Were the fan clutches the same for late C1s and C2s?
                        I know there is a difference in small block and big block, i.e. measurement from the mounting flange to the base of the bolts (boss) where the blade mounts.
                        How does this one look.
                        Don Harris
                        • Larry M.
                          • January 1, 1992
                          • 2701
                          Re: C2 Fan Clutch
                          Dave
                          David:
                          The date E11F should be May 11 1965..........not 1966 as stated.
                          Larry
                          • David L.
                            • July 31, 1980
                            • 3310
                            Re: C2 Fan Clutch
                            Larry,
                            You are correct. The code "E11F" should be May 11, 1965. I guess I had a "senior moment". Thanks for the correction.
                            Back in the Spring of 2011 I bought a similar fan clutch ink stamped "EATON", "CJ", and "L27G" (Nov. 27, 1966) that came with a Scwitzer fan dated "L6" (Nov. 1966).
                            Jerry from California has a "CJ" fan clutch dated "L12G" (Nov. 12, 1966) on his 67 Corvette that he owned since 1968.
                            See link below.
                            Dave
                            https://www.forums.ncrs.org/showthre...ghlight=clutch
                            • David L.
                              • July 31, 1980
                              • 3310
                              Re: C2 Fan Clutch
                              Don,
                              It does seem a bit odd that a few days after responding to your thread about C2 fan clutches I would find another one. However, it was not a great day at the swap meet for me. I traveled about 175 miles (round trip) to Connecticut and only bought 3 parts, all were $5 each. In these modern times it is very difficult to find vintage parts at rock bottom prices. The swap meet at the Thompson Speedway is primarily "race guys" selling their racing parts and fortunately most of them have very little interest in original Chevrolet parts. I have done well there over the last 20 or 25 years but the pickings are now very thin.
                              Dave
