63 Throttle linkage question - NCRS Discussion Boards
  • Edward J.
    • September 15, 2008
    • 6958
    I was looking at the AIM and have a question, It shows cotter pins to retain the throttle rod at each end on my 327/340 engine, I was thinking that the return spring is suppose to retain the rod at the carb. ??? Thanks, Ed
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: 63 Throttle linkage question
    Ed,
    The return spring is what I used and I believe it to be correct, the picture in the AIM may be mined from a passenger car. Makes you wonder because the spring has a large loop that seems to fit the plastic bushing.
    • Edward J.
      • 6958
      Thanks Tim. I remember seeing a post a while back and it was for a later C2 I guess it must have stayed that way through 67 for the small blocks.
      • Michael H.
        • January 29, 2008
        • 7477
        Does the AIM drawing show a cotter pin with a part number for the throttle rod?
        • Edward J.
          • 6958
          Mike, yes the cotter pin part no. is 121222. Mike I happened to look inside the 63 shop manual and it also shows the cotter pin installed?? what do you think?
