67 glove box light shield - NCRS Discussion Boards
  • John S.
    • May 17, 2009
    • 164
    Does the glove box light shield need to be original for no deducts, or is repro ok for judging?
  • Don H.
    Moderator
    • June 16, 2009
    • 2288
    Re: 67 glove box light shield
    John
    Your entire car can be built from repro parts, from the frame, wheels and tires, to the body panels and top, and every part in between and it is OK for judging. The deducts are determined based upon how similar to or dissimilar to original parts your repro parts appear. Degree of original appearance is determined based upon configuration, date, completeness, installation and finish. So,,, if the light shield you use closely matches an original, you will not suffer any deduct in judging and you will be OK.
    • John S.
      • May 17, 2009
      • 164
      I understand an original has an o stamped on it, the repro ones I have seen do not. Will this entail a deduct if no o?
      • Michael G.
        • January 1, 1997
        • 1251
        Could be the case however, what does your judging manual indicate? In my experiences no judge has ever made that indication, furthermore if shield did would most likely be too small to see where positioned. In closing no judge will ask you to remove.
        • John S.
          • May 17, 2009
          • 164
          So stamped o is not visible when shield is in place? I have not seen one to know where it is stamped and if it could be judged on shield or not..
          • Michael G.
            • January 1, 1997
            • 1251
            So stamped o is not visible when shield is in place?.
            Don't know if shield has anything stamped on it which is why I asked what your judging manual indicated.
            • John S.
              • May 17, 2009
              • 164
              Judging manual does not specify, but there are lots of things not covered there. Like how would one know the glove box key cannot come out if half turned for ops check? I had been told at Texas regional they had an o stamped on the if original shield. Just not sure if it shows and can be seen when judged. I do not have an original one, so asking on the forum what I need to be correct.
              • Gerard F.
                • June 30, 2004
                • 3806
                John,
                In my experience with 67 interior judges at Nationals, they do look for the "O" on the glove box light shield, as well as the "P" on the glove box striker, and do make a minor deduct if not present.
                Both the "O" and the "P" are in the Judging Guide.
                Take a look at the first archived thread below for pictures of the shield and striker with the above letters.
                Jerry Fuccillo
                • John S.
                  • May 17, 2009
                  • 164
                  I have the P on my latch. Need a shield with the stamped O. Anyone know where I could get one? Thanks,John
                  • Steve B.
                    • March 1, 2002
                    • 1195
                    John, I would check on ebay and place a want ad on the driveline. My guess is that you will be able to find one.
