OT help needed 59 Buick - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    I want to remove a door which is attached in the hinges by Phillips head bolts. They won't budge using a large Phillips head screw driver. Is there Phillips head attachment for use with a neumatic air gun?
    joe
  • Jim D.
    • 2885
    Re: OT help needed 59 Buick
    Use an impact driver. -
    • John S.
      • July 29, 2009
      • 640
      i would use a "hand impact driver". the downward impact of a hammer, plus rotation at the same usually frees up frozen fasteners.
      • Keith B.
        • March 7, 2008
        • 928
        When I went to remove my doors from my Chevelle that used the same screws. I used a large Phillips bit on a 3/8 drive ratchet with a big breaker bar. And tap the bit with a hammer every so often. The key is to have the correct Phillips bit
        • Joseph T.
          • April 30, 1976
          • 2074
          Thanks for the answers from everyone. Will get an impact Phillips and give it a go. Wife backed into the 59 Buick
          • Dick W.
            • 10483
            Joe, if you have a 4# or better dead blow hammer, it will work better than a regular hammer
            Dick Whittington
            • Dennis O.
              • December 1, 1988
              • 438
              One of my other obsessions is traditional Hot Rods. I stole this from the H.A.M.B. Thanks to member SAMIYAM over there.
              Tech Tip 309... Rusty Hinge Screw Removal
              As an aircraft mechanic, I learned how to deal with the removal of screws... thousands of them... and I have the forearm to prove it!
              But NOTHING compares the the frustration of removing rusty screws in our old cars... and those of you who have ever removed a door hinge screw... you know they can be a bitch!
              So a couple of years ago I was removing some rusty hinges on a '50 Ford... they had never been off, and despite the car being
              a one owner california car... they were STUCK! So after soaking them with Tri-flow, WD-40 and liquid wrench... I dug out the old "Hammer-the-****-out-of-it" impact screwdriver... and proceeded to mushroom one of the Phillips headed screws on one of the hinges...
              Then the owner showed up... a guy who is the definition of "anal retentive"... he also happens to be the owner of the FBO that I worked at... so he knows how to un do screws!
              So, he takes one look at the screw, gets that look on his face, and then says that he has just the thing I need to take those screws out... even the one that was destroyed.
              What he described was a tool that Snap-On makes... but for FREE... I whipped one out myself in about 15 minutes...
              What it is:
              Basically it is an adaptor for your air hammer...yea, they usually come with a chizel, a sheet metal cutter and a punch... and bein's that I buy the cheap ones at Kragen, I usually have an extra chizel or two lyin' around...
              So, I hacked the end off of a bit... ground the chrome off a Tiawan 1/4" socket... welded that to the end of the old chizel and then welded an arm made out of 3/8" rod onto the side.
              To use this wonder tool... all you do it install it in your air hammer, put a tim in the end of it and then lightly apply pressure to the trigger... now you don't have to go to town on it and put full line pressure to the hammer... just a dat-dat-dat-dat-dat-dat rhythm will do.
              Once you give it a dozen hits or so, begin applying pressure to the handle and the screw will come out... guaranteed you will NEVER have to drill another screw out again.
              Oh yea, this tool is a little hard on the tips... so you will go through them quite often... I have pictured a 5/16" tip, which may be the hot set up...
              Anyway, here's a pic of the parts to make one, an air hammer and a completed screw extractor.
              Screw away!Sam.
