65 BB u joints - NCRS Discussion Boards
65 BB u joints
  • Bill W.
    • March 1, 1980
    • 2000
    65 BB u joints
    Does anyone have photos of original 65 BB drive shaft u joints ? I just removed my 31,000 mile joints and they do not have grease fittings and have a circle indent in the center on both sides . It was a drag race car so Im not sure if they are original .
    • 43295
    Re: 65 BB u joints
    Bill-----
    Big block and small block u-joints were the same. Based upon your description, I would say that your u-joints are originals. However, I would also be surprised if they're not scrap at this point, notwithstanding the low miles. Remove the caps. If any of the trunnions' bearing surfaces are brinnelled, even slightly, they are not fit for further use.
    • Bill W.
      • March 1, 1980
      • 2000
      Re: 65 BB u joints
      Thanks Joe .
      • Wayne M.
        • March 1, 1980
        • 6414
        Re: 65 BB u joints
        Bill -- Here are what I believe to be original U-joints; these off a complete 4.56 rear end with casting/assy dates of Jan/Feb 1964, and low miles, as was bought [previous owner] in 1968 for a hot rod project but never used.
        The casting numbers are GM_59_8 and 3705377, and 4118 on the other side (as far as I can make out)
        There is visual evidence of early 'Brinell'ing, but not detectable running your fingers around the trunion.
        • Bill W.
          • March 1, 1980
          • 2000
          Re: 65 BB u joints
          Wayne were these from the drive shaft or the axle shaft ?
          • Wayne M.
            • March 1, 1980
            • 6414
            Re: 65 BB u joints
            Oops, sorry. These were from axle shafts .
            • Alan D.
              • January 1, 2005
              • 2055
              Re: 65 BB u joints
              Here are some typical factory drive shaft U Joints
              • Bill W.
                • March 1, 1980
                • 2000
                Re: 65 BB u joints
                Thanks Alan thats what mine look like .
                • David L.
                  • July 31, 1980
                  • 3310
                  Re: 65 BB u joints
                  Bill,
                  The U-joint pictured below (top photo) came off a 1970 Z28 (March 1970). It has a Chevrolet bowtie at the center.
                  The second photo is a U-joint from a 1966 Corvette.
                  Dave
                    • 43295
                    Re: 65 BB u joints
                    David-----
                    I believe the "Bow-Tie" is a foundry mark which represents one of the GM forge plants (i.e. Tonawanda, Detroit, or Buffalo). In those days, those forge plants were run by Chevrolet but produced parts for all GM divisions. Unfortunately, GM spun off these forge plants to American Axle and Manufacturing which eventually shut them all down. Today, GM has no in-house forging operations.
