1957 Engine Stampings - NCRS Discussion Boards
  • Steven B.
    • June 30, 1982
    • 4016
    Can anyone share some pictures of original 1957 engine stampings and distributor and generator tags?
    Thanks!
    Steve
  • Edward L.
    • 278
    Re: 1957 Engine Stampings
    Email me at edlepelis@verizon.net and I will send you two.
    Ed
    • David S.
      • December 1, 1982
      • 310
      DSC07900.jpgDSC00645.jpgDSC06052.jpgTry these Steve Dave
        Here's another one.
        • Bruce B.
          • May 31, 1996
          • 2930
          Dist and generator are packed away.
          • James G.
            • May 31, 1976
            • 1556
            Here's another one.
            [ATTACH=CONFIG]48762[/ATTACH]
            John, the last letter ''H'' looks like it was applied after the F522F was stamped. Do you have any comment on this? I have seen the ''L'' in the 57 Fuel engines ''EL'' suffix stamped in similar fashion.
            • John S.
              • July 29, 2009
              • 640
              first five are gangstamped . the one i would question would have been the L. that would be a one-in-a-thousand strike to get the L perfectly in line with the gangstamp.
              • Charles H.
                Infrequent User
                • June 30, 1997
                • 11
                I'm going to tag onto this thread if that's ok. Yesterday I looked at a 57 FI that had a code stamped "F610P". Does anyone know what this block came out of?
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  According to my Lime Book there is no "P" suffix on small block engines but lots of P with another letter.
                  • Charles H.
                    Infrequent User
                    • June 30, 1997
                    • 11
                    Thanks Bruce, I'll try for a better look at it in the next few days. It was dark and dirty!
                      Jim -
                      The second suffix character on a '57 pad is almost always misaligned with the first five, as the second suffix character was stamped separately by hand with a loose die (not included in the gang holder).
                      • Scott S.
                        • March 1, 1979
                        • 747
                        Please pay special attention to the V on the generator tag. The replacement items have a very narrow opening at the top.
                        Scott
                        • Edward L.
                          • 278
                          I have two original 1957 engines, (EH, EG). In both instances the last character of the suffix is not in alignment with the rest of the stamping due to the use of a gang holder with a 5 character capacity.
                          The current 56-57 judging manual addresses this issue. It also includes photo's.
                          Ed
                          • Cecil L.
                            • May 31, 1980
                            • 450
                            P was a truck engine code.
