435 HP end carb. metering plates????? - NCRS Discussion Boards
  • George P.
    • August 31, 1988
    • 17
    On the 1967 427 435 HP end carbs (3659's) what is the holley pt. no. on the stock metering plate. What size opening should the "main hole" and the "idle hole" be on the proper metering plate??? Thanks in advance for any help on this.
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: 435 HP end carb. metering plates?????
    They are identified by a "-3" stamped on them.
    • Timothy B.
      • April 30, 1983
      • 5196
      This is what I found, 34R9716-3 Secondary Metering Plate, Main Hole 0.055, Idle Hole 0.026
