1969 BB Exhaust replacement - NCRS Discussion Boards
  • Kevin M.
    • August 12, 2013
    • 5
    Hi All,
    Does anyone know if the replacement exhaust systems sold by Corvette Central or Year One are NCRS compliant?
    I know the aluminized will be a deduction. Wondering about the bends, clamps, etc. I don't see any wrinkles in the bends in the pictures they have posted like Gardner Exhaust says they have.
    I would really like to put a 1968 2-1/2" system on my 427/390. But want to stay original so guess I'll go with the 2".
    Kevin
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1969 BB Exhaust replacement
    Hi Kevin,
    There are a number of threads in the archives on this subject. Here is one that may help you. https://www.forums.ncrs.org/showthre...haust-Question
    I purchased my exhaust system for the '68 from Allen's http://www.allencorvetteexhaustsystems.com/
    Good luck on the project.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Kevin M.
      • August 12, 2013
      • 5
      Thanks Terry,
      so you decided on Allen's even though they didn't have the wrinkles? did you get the 409 stainless or aluminized. I'm concerend about the deductions for finish and config.
      I'm impressed that you have three awards.....ultimatley what I'm after too!
      Kev
      • Terry B.
        • August 31, 1999
        • 607
        Hi Kevin,
        I purchased my exhaust system about 7 years ago. At that time I went with the recommendation of a very high level judge of 68/69 cars who I respected and still do. I went with the aluminized system. Now 7 years later if I was going to purchase an exhaust system I would do research on what system is going to be the best for my application. Talking to national team leader, Chuck Berge, would be one of the first things I would do. I would also speak with 400+ level chassis judges of 68/69. I would expect a few to respond to this thread. As you will discover, no one sells a perfect exhaust system but there are some that are better than others. Getting an aluminized or stainless system will most likely mean you will never have the need to purchase another exhaust system for that Corvette.
        I lost points on configuration and finish on my exhaust system but to my knowledge, everyone does.
        Terry Buchanan
        Corvettes Owned:
        1977 Coupe
        • William H.
          • January 1, 2006
          • 209
          Kevin. I really like Gardner's system and I think it's the only one with the mandrel bends. When I researched for my '68 427 last year, the Gardner system was the closest match. It costs a little more but I thought it was worth it.
          Bill Hyndman
          The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
          1962 Big Brake Fuelie
          1965 Fuelie Convertible
          1968 L89 Convertible
          • Don L.
            • August 31, 2005
            • 1005
            +1. I chose the Gardner system as well and am very happy with it. As stated above,no reproduction/replacement system comes without some level of deduction, but for me, this system looks very close to right, especially where the pipes go into the mufflers. The fit was fantastic and the sound is nice too.
            No regrets.
            Don Lowe
            NCRS #44382
            Carolinas Chapter
            • Mike F.
              • April 25, 2011
              • 668
              If I had a 427/390 I wouldn't strangle it with 2" for a couple of points.
                • 11666
                It will be more than a couple of points if you go with a different exhaust size, as it affects the configuration of every piece except the tips.
                Each has to do their own calculation to determine if its worth it or not.
                • Jim T.
                  • March 1, 1993
                  • 5351
                  I preferred the original type 2 1/2 inch system on my 68 L79 and when I took the 69 Corvette side pipes off my 1970. I installed the 2 1/2 inch exhaust pipes on my 1970. Installed the 2 1/2 inch exhaust pipes at least 24 years ago.
                  • Dick W.
                    • 10483
                    Agreed Bill
                    Dick Whittington
                      William -
                      Common misconception, or just a semantics issue - no Corvette exhaust system ever had "mandrel bends" - they were formed with external dies/shoes, and had "wrinkles" in the bend radii. Mandrel bending equipment is slow and expensive, and that process wasn't used for OEM systems.
                      • Stuart F.
                        • August 31, 1996
                        • 4676
                        On a related matter; my son's 69 L-89 has had side pipes installed (not original). I was surprised to see they are correct at 2". My question involves the heat riser valve; It seems to open near full open position, then locks up for the last bit of travel. One can move it forcibly by hand, but I doubt the exhaust pressure would push it full open and then, if it did, it seems like it would stick full open. Never saw one do that. I recommended to him that if he decides to keep this car would be to stick a spacer block in there and forget about the darn valve, specially here in Florida.
                        Stu Fox
