54 Radio fuse - NCRS Discussion Boards
54 Radio fuse
  • Brad H.
    • August 12, 2007
    • 724
    54 Radio fuse
    Hi. I turned on the 54 radio on a cruise the other day and nothing. Got home and fuse was blown. I checked all connections at radio etc. and put in another fuse and turned it on and it hummed for a few second's then blew the fuse again. What should be checked? Thank you. Brad.
  • Jim L.
    • September 30, 1979
    • 1816
    Re: 54 Radio fuse
    I'd look at the power supply on the back of the speaker. The power supply uses "electrolytic" capacitors which, over time, can develop short circuits across their terminals. There could be other PS problems, of course, but my money is on the capacitors.
    Jim
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54 Radio fuse
      Jim
      Hi. Brad here. I went out this morning and turned off power to car then put in new fuse put back power only fuse is fine, then turned on car (started) fuse is fine, then turned on radio, no noise got under dash and wiggle little plug connector and it started the radio without fuse blowing, ran for five min. or so still ok. Could that plug in too far or not enough blow the fuse? Hmmm. Thank's, Brad.
      • Jim L.
        • 1816
        Re: 54 Radio fuse
        Brad,
        No such thing as having the connector plugged in too far. Scratch that idea. As for not being plugged in far enough, I can imagine a scenario in which the fuse might blow. However, that scenario includes the assumption that the electrolytic capacitors have degraded.
        When you replaced the fuse, did you do so with a fuse of the same rating as the one you removed?
        Jim
        • Chris S.
          • January 1, 2000
          • 1068
          Re: 54 Radio fuse
          The plug at the bottom of the pack can become easily unplugged
          I have had that happen
          Also check at the power block on the firewall - check the plastic holder and spring - I have stretch the spring in order to hold the fuse tight and make good contact.
          • Brad H.
            • August 12, 2007
            • 724
            Re: 54 Radio fuse
            Jim/Chris 14 amp fuse is what has always been in holder, I will check to see if the spring has enough tension. Also is that speaker with power source on it a radio guy check or can my electrical device guy check and repair this if bad caps etc? Thank you, Brad.
            • Jim L.
              • 1816
              Re: 54 Radio fuse
              I would recommend you take the radio and power supply to a radio guy. Radio work, in general, requires specialty instruments and specialized knowledge that someone experienced in radio repair will have.
              Jim
              • Brad H.
                • August 12, 2007
                • 724
                Re: 54 Radio fuse
                Thank you for the input. Brad
