Re: 1972 car starts and dies - towed home
Larry, I will give you quick test of the wiring. The coil should have power with the ignition switch in run position this is the wire coming from switch and heading out into engine compartment, so if there is power at the + side of coil, that side of wiring is okay, the next is the start position of ignition switch the solenoid engages and feeds the coil the full 12 volts. This wire comes from the solenoid R terminal and heads up to coil and is tied in with the resistor wire on top of coil from fire wall. good luck
