Decking the engine - NCRS Discussion Boards
Decking the engine
  • John C.
    • September 30, 2001
    • 130
    Decking the engine
    Why does that remove the numbers on the pad?
    • 43246
    Re: Decking the engine
    John------
    The engine stamp pad on most small blocks and big blocks is an extension of the block deck surface on the right (passenger) side. So, if the block deck surface is milled ("decked"), an equal amount of material is naturally removed from the block deck (i.e. cylinder head seating surface) as well as engine stamp pad. If the thickness of the material removed is greater than the depth of impression of the stamp pad characters, then the characters are also removed.
    Virtually all machine shops use a rotary broach to mill the block deck surface. With such a machine it is virtually impossible to mill the deck surface without also milling the stamp pad.
    The shame of it all is that very few blocks need to be "decked".
    • Michael J.
      • January 27, 2009
      • 7140
      Unless, of course, you want to stamp some new numbers that "match".....
      • Bruce B.
        • May 31, 1996
        • 2930
        No need to deck a block if you want to change the numbers.
        A good technician can remove the numbers by hand, manually apply lines similar to broach marks and then stamp the block.
        • Terry D.
          • May 31, 1987
          • 2696
          You mean someone would actually do that to make a car more valuable? I a speechless! LOL
          • Bruce B.
            • May 31, 1996
            • 2930
            Terry,
            No one in Ohio would ever think about doing that.
            Bruce
            • Michael J.
              • January 27, 2009
              • 7140
              Terry,
              Bruce
              ...+1
              • Robert K.
                • July 31, 1984
                • 213
                How does a technician remove number by hand?
                I recall a Vette Vues artical many years ago about an original 435 car have the engine decked after being told not to. They tried everything, even confurring with the FBI to get their numbers back. They finally heated the pad cherry red and the numbers popped back out. I wonder how that would fair on the judging field?
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Using a file, sandpaper and whet stones.
                  The heating technique seems doubtful to me.
                    • 43246
                    Robert-----
                    No process that I know of, including forensic processes to "raise" ground off numbers on things like guns, etc., will permanently restore stampings which have been filed or ground off. These processes may be able to allow the numbers to be discerned on a very temporary basis, but they absolutely do not provide for the permanent restoration of the numbers. Temporary discernment is all that forensic investigators care about but it's not, at all, what automotive restorers care about.
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      Since it wouldn't look anything like a factory original pad and proving authenticity of pads is not the purpose of judging, I'd imagine a full deduct.
