water leak - NCRS Discussion Boards
water leak
  • Lyndon S.
    • April 30, 1988
    • 1027
    water leak
    I am getting water on the inside of my lower door panel carpet an the carpet on the frame rails. I put new weather stripping on the doors. When ever I wash the car these two places get soaked. Could it be coming from other seals like the A pillar weatherstripping and running down into the carpet? I have not replaced any of the weather stripping. Any way it could be the door itself?
    • 6957
    Re: water leak
    Lyndon, water leaks can be a PIA , my advice is sit in the car with a good flash light and have someone use a water hose around the door and look closely to see if you can see where its starting from. Keep the water in just the door area first, then if there is no leak head to the piller post area next with the water.
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: water leak
      Will try that and see if I can find where it's coming in.
      • Bill W.
        • March 1, 1980
        • 2000
        Re: water leak
        Remove the door panels and check for water coming through the vapor barriers .
        • Lyndon S.
          • April 30, 1988
          • 1027
          Re: water leak
          I have put new barriers on from Mid America is it that they could be what is leaking?
          • Bill W.
            • March 1, 1980
            • 2000
            Re: water leak
            yes if not sealed to the door and covering all holes they will leak . With the interior door trim off spray the door panel with water . At work we installed a shower head on a 8 foot water pipe on wheels that was our rain . GMs warranty said the car should not leak in rain conditions . Hard spray or car washes were not included .
            • Ed N.
              • May 16, 2010
              • 1003
              Re: water leak
              Lyndon, I have VSH tape from GM showing how to address water leaks on C4s. Send me a PM. Maybe I can order a copy and send it to you.
              Ed Nieves
              NCRS #51799
