68 Steel Wheel Semi-Gloss Primer - NCRS Discussion Boards
  • Jeff P.
    • 799
    I just had my 5 wheels Acid Dipped. They will be done this week. I'm planning at least to etch,prime them. I checked the archives but never found what the pros use for a self etch,prime semi gloss black. Any help would be great. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
    • 6950
    Re: 68 Steel Wheel Seni-Gloss Primer
    Jeff, I used a etching primer on my 72 wheels. I Think its a good idea. If your using a spray can, that is the way to go.
    • Michael M.
      • February 1, 1993
      • 604
      Jeff, the best primer I found for bare metal is a product from PPG. It's DP90LF, which is a non sanding epoxy primer. It has the correct semi-gloss black color you are looking for. You mixing ratio is 1:1, one part primer to one part hardener.
      • Jeff P.
        • 799
        Thanks,Ed and Mike. Mike, do I Etch with anything or is it self etching.
        • Michael M.
          • February 1, 1993
          • 604
          Jeff, DP90 properties are its a corrosion-resistant primer and a primer/sealer. You can directly apply it to bare metal. Etching primer is not needed but will never hurt if you want the extra step. The ratio is 2:1 not 1:1.
          • Jeff P.
            • 799
            Thank you all,great advise
