What is acceptable? I cannot find specs anywhere or info via searces here.
A machine shop left me with a mess. I got the hardware 3rd party of a takeover project. Using a gauge block I'm seeing apx 0.003" to 0.005" difference between upper and lower "Y" between several cylinders. Both sides. I also measure 0.010" difference between the front cylinder deck area flats to the intake manifold angled walls(ears), and the rear cylinder flats to rear walls. Both decks.
Unfortunately this was after assembly, start up and cam break in after 20 min at 2000 rpm, running fine, went to idle and coolant overflowed within seconds. Reran after cool down and water refill 3 times. Ran fine up to 180. When 180 thermostat opens, coolant forced out the overflow. Coolant proved to be pressurized by combustion leaks. Leak down test proved 3 bad cylinders(6,5,7)at 18 to 22%, combustion gasses in coolant using dye test. Tore it apart. Both heads are a problem. I find out later heads were NOT decked, just cleaned up. Magnafluxed and pressure tested post failure and passed. Heads being redone 100% at different shop, now I'm checking block and have concerns.
Using Felpro composition gaskets which help the cause, but I don't like the variations I'm seeing on the block deck measurements. Please.....Lectureless technical opinions welcomed.
