plug wire support question - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    66 small block spark plug wire support . Lower right hand side has a strap with 2 notches each side for the 4 plug wires. What does this bolt to? UPC sections no help
    Randy
    • 43258
    Re: plug wire support question
    Randy
    Randy------
    It attaches with a single, short 1/4-20 bolt to the block. The "tang" at the upper end of the support fits into a small hole drilled in the block in order to prevent any rotation of the support.
    • Gene M.
      • April 1, 1985
      • 4232
      Randy------
      This mounting position (1/4 -20 thread and hole) is on the bell housing flange (behind the head) area of the block on right side.
      • Randy S.
        • January 1, 2003
        • 586
        Thanks guys. Mine is obviously missing and I was looking for the threaded hole.
          Randy
          Randy -
          It's shown in UPC 6, sheet B3, item #12 support.
          • Randy S.
            • January 1, 2003
            • 586
            Thanks John. I saw that but still couldn't figure out where to look for the mounting hole. Gene tells me its on the bell housing flange. You mean you don't have a picture of this in your vast photo library
            Randy
              • 43258
              Randy
              Randy-----
              It should be pretty easy to find on the bellhousing flange of the block but here's a picture, anyway.DSCN2902.jpg
