C1 Wheel Question re: NT and GM stamped wheel - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    These are 15 x 5 wheels with the 5 x 4 3/4" hole pattern and the 5/8" valve stem hole diameter. Not sure what all these dimension wheels fit, but I assume they are the same for 56 through 62 Corvette and at least 55 and 56 Chevys.
    I am trying to figure out what I have. I found a old thread that said the NT stamp was for Norris Industried and they were not a supplier to GM. However, as you can see from the pictures, the nubs by the lug holes have a GM stamp on one and and NT stamp on another. The inside is stamped "Made in USA 15X5K N T E 6".
    Since they have the GM stamp, is it possible they are a later service replacement?
    Picture attached.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • David L.
    • July 31, 1980
    • 3310
    Re: C1 Wheel Question re: NT and GM stamped wheel
    Donald,
    Is there any stampings near the valve hole? What is the wheel offset?
    You can measure the wheel offset as follows:
    Carefully measure the gross width of the wheel. A 5" wide wheel should measure approximately 6.0" +/-.
    Carefully measure the backspacing. It is the distance from the back edge of the wheel to the surface that mounts against the drum. The backspacing might measure about 3 5/8".
    Offset = (backspacing) - (1/2 X gross width)
    Example:
    Offset = (3 5/8") - (1/2 X 6") = 5/8"
    BTW, I have seen assembly line installed Norris Industry wheels on 1970 Camaro SS models but the Kelsey-Hayes wheels are much more common. Both types are stamped "CL" by the valve hole.
    I have never seen "NI" wheels made in the 1950's.
    Dave
      Originally posted by Donald Harris (51003)
      I found a old thread that said the NT stamp was for Norris Industried and they were not a supplier to GM. The inside is stamped "Made in USA 15X5K N T E 6".
      Donald -
      They might be, but based on the date stamp format, they're clearly not Kelsey-Hayes wheels from that era. Photos below show typical 1956 and 1961 Corvette wheels with their size and date stamps, K-H logo, and TRA logo stamp.
      • Donald H.
        • November 2, 2009
        • 2580
        Originally posted by David Liukkonen (3775)
        Donald,
        Example:
        Dave
        I don't see any stamping around the valve stem hole. The wheel does measure 6" gross width. And the backspacing does measure approximately 3 5/8". It has the same measurements as a Kelsey-Hayes welded dog bone wheel that I had for my 1960. By the way, this NT wheel had spot welded center section.
        Don
        Don Harris
        • Donald H.
          • November 2, 2009
          • 2580
          Donald -
          Don
          [ATTACH=CONFIG]48495[/ATTACH][ATTACH=CONFIG]48496[/ATTACH]
          I have a couple of Kelsey-Hayes wheels, the welded dog bone type. Your picture begs another question. the wheel stamp is 15x5K. Do you know what the K signifies?
          As I mentioned above, this NT wheel is also stamped 15X5K.
          Don Harris
          • Donald H.
            • November 2, 2009
            • 2580
            John,
            I also noticed something else. What I think you refer to as the TRA logo stamp. What is that?
            On the two Kelsey-Hayes wheels you pictured, one of these logo's has an 8 in it and the other a 4. The NT wheel I pictured also has this stamp with a '0' in it. The Kelsey-Hayes wheel that I have handy also has a 4 in this stamping.
            Don Harris
            • Cecil L.
              • May 31, 1980
              • 449
              I have a full set of GM NT wheels 14X5 on my 57 BelAir and I have seen many others, but I believe they were mostly 14's.
              • Dan A.
                • May 31, 1974
                • 1074
                [QUOTE=Donald Harris (51003);680127]
                QUOTE]
                The TRA logo is the Tire & Rim Association logo. In the attached photo I have errored and called the Tire & Rim Association logo the Wheel & Rim Association.
                  Donald -
                  The "K" is the SAE descriptor for that particular rim cross-section, including the presence/absence of inboard safety beads.
                  • Kelly W.
                    Infrequent User
                    • April 1, 1996
                    • 5
                    Hi DanielI am looking for a picture of a May or June Dog Bone wheel....Would you happen to have one?Thanks!!KellyKelly Waite27432
                    • Dan A.
                      • May 31, 1974
                      • 1074
                      I own this wheel. It is a dog bone wheel dated March 1956, 56 3.
