Hoist for 1958 hardtop - NCRS Discussion Boards
  • Sara W.
    • October 21, 2008
    • 11
    Hi can anyone recommend a good hoist for my 1958 hardtop for long-term suspension? Name and where to buy? I was thinking of an electric one but since I don't anticipate using it much if ever, would you recommend just a manual one?
    Sara
  • Rick A.
    • July 31, 2002
    • 2147
    Re: Hoist for 1958 hardtop
    Check the following link - http://www.hoistlifts.com/hard-top-hoist/
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Sara W.
      • October 21, 2008
      • 11
      Awesome, thank you
      • Georges C.
        • June 17, 2013
        • 72
        Harbor freight has an electrical hoist winch with remote button control and auto lift shut off. I have my '66 hardtop hanging from one mounted to the ceiling ( top only weighs about 50 lbs?). Best part - it is only $99.00.
        see link:
        http://www.harborfreight.com/110-vol...rol-40765.html
        • Sara W.
          • October 21, 2008
          • 11
          Awesome, thank you
          • Sara W.
            • October 21, 2008
            • 11
            What did you use to strap it and attach the winch?
            • Troy P.
              • February 1, 1989
              • 1284
              I made my own with an eye bolt screwed into a beam in the garage ceiling, 2 pulleys, rope and a hand crank winch that goes on a boat trailer. I used 2 nylon web straps to attach the top to the hook on the bottom pulley. Very inexpensive. With a two part line in the pulleys you really don't need a winch because the top is so light you can easily pull the rope by hand.
              Now I have a larger shop with lots of floor space. So I made a rack to hold the top. $15 worth of parts.
              DSC00153 (Small).JPGDSC00154 (Small).JPGDSC00157 (Small).JPGDSC00158 (Small).JPG
              • Philip P.
                • February 28, 2011
                • 558
                Troy
                I like your stand, one question I have heard or been told that the top should not rest on the window. I have a wall mount and have the top with the front header resting where you have you back window. Any problems or views.
                Phil
                1960
                • Troy P.
                  • February 1, 1989
                  • 1284
                  I can see how it might possibly distort sitting on the window end. But I noticed all the commercially available expensive metal rolling stands are designed for the top to sit that way. I very rarely put the hardtop on so I haven't noticed a problem with fit.
                  • Georges C.
                    • June 17, 2013
                    • 72
                    I made one from boat ski poly rope and 3 's' hooks. One in each of the top front clamps, over the top and one at the rear center window - my 66 has a metal tab with hole. make the fronts short so the front clamp touches the top first so that you can guide the lower attaching point and not scratch the parts.
