1966 a/c control valve grease fitting - NCRS Discussion Boards
+ More Options
Posts
  • Harry L.
    • December 22, 2008
    • 370
    My original a/c control valve has a lubrication fitting, but my new repo a/c control valve has an allenhead plug where my lube fitting was. Do I need to remove that allenhead plug and install my original lube fitting or do I not need to lubricate the new control valve? Here are pics of what I am talking about. Dutch
    Re: 1966 a/c control valve grease fitting
    Originally posted by Harry Long (49801)
    My original a/c control valve has a lubrication fitting, but my new repo a/c control valve has an allenhead plug where my lube fitting was. Do I need to remove that allenhead plug and install my original lube fitting or do I not need to lubricate the new control valve? Here are pics of what I am talking about. Dutch[ATTACH=CONFIG]48469[/ATTACH][ATTACH=CONFIG]48470[/ATTACH]
    Dutch -
    Leave it alone. That grease fitting is/was only for use during assembly of the valve itself, and most new or rebuilt valves I've used come with a plug and a warning card or stamp that says NOT to use a grease fitting there or it will void the warranty on the valve (damages the seals).
    • Harry L.
      • December 22, 2008
      • 370
      Thanks John
        Dutch -
        Dutch -
        Not sure if I mis-read your post or not - I thought you were talking about the power steering control valve, not an A/C valve - A/C valves don't have grease fittings.
        • Harry L.
          • December 22, 2008
          • 370
          John, you were correct, I do not know why I put the the a/c in the thread. Thanks for your reply. Dutch
