C3 Tire question - NCRS Discussion Boards
C3 Tire question
+ More Options
Posts
  • Don C.
    • October 11, 2011
    • 18
    C3 Tire question
    My 1969 Build Sheet/Corvette Order Copy does not indicate any specific tire size/brand or option codes. What does this indicate? That it may have originally came with some type of black wall tire? It currently has repro F70-15 Firestone Red Lines.
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: C3 Tire question
    it would seem to that the base tire was what came on your 69. Should be a re pop goodyear for judging, as no re pop firestone tire is even close to what would have came on a 69.
    • Tom H.
      • December 1, 1993
      • 3440
      I would think the lack of an optional tire on the sheet would indicate the standard tire. I would think that would have been a blackwall.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Bill C.
        • July 15, 2007
        • 904
        prior to September 1969, the car would have been delivered with a white or red strip tire (not sure about black walls).
        The RWL tires were not available until late 1969 production.
        Only Goodyear tires will pass judging with minimal deductions.
        • Don C.
          • October 11, 2011
          • 18
          I guess that was part of my question...what was the standard tire for these cars circa March 1969?
          • Tom H.
            • December 1, 1993
            • 3440
            As far as I know, the blackwall was the standard 69 tire.
            Tom Hendricks
            • Bill C.
              • July 15, 2007
              • 904
              page 46 - blackwall was standard.
              • Don C.
                • October 11, 2011
                • 18
                Thanks for the quick response info folks. Bill C. in your last post you referenced page 46? Page 46 of what?
                • Bill C.
                  • July 15, 2007
                  • 904
                  Technical Information and Judging Guide.
                  • Don C.
                    • October 11, 2011
                    • 18
                    Thanks Bill...which edition ...I have three of those. I looked at them but must have missed that reference. If your are restoring a 1969 427/435 it sounds like we are in the same boat.
                    • Kurt G.
                      • April 30, 2005
                      • 343
                      Don, Don't sweat the red stripe as it was an original tire style for you car. Also, don't turn it around to black-side out cuz that will kill the points for judging. The size is right, and if they are Goodyear your deducts will be minimal. Kelsey Goodyears are pretty much spot on, Coker Firestones, not so much.
                      Kurt Geis
                      Chairman, Midway USA Chapter
                      Targa Blue 1972, Top Flight and Duntov Award, 2014
                      Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                      Arctic White 2013 60th Anniv Special Edition Conv.
                        • 43255
                        Tom------
                        That's what it was. No matter when in the 1969 model year it was built, early, late, or in-between, the standard tire was an F-70-15 BLACKWALL.
                        • Bill C.
                          • July 15, 2007
                          • 904
                          4th edition - newest one available.
                          if you have an older one, just look for the section for Exterior and tires/wheels should addressed in it, likely towards the end.
                          • Don C.
                            • October 11, 2011
                            • 18
                            Thanks Bill, I have the 2ed,3ed and 4th editions, I will review those again but I believe you and the other folks here have confirmed what I had suspected about the standard tires. Again thanks for the clarification, now all I have to do is decide how far to take this little jewel.
                            • Steve M.
                              • January 1, 2006
                              • 258
                              I have a 1969 convertible with what I thought was an original spare. The tire is a F70 15,Goodyear, Speedway, Wide Tread tire that does not look like it has been on the ground. It still has the rubber 'whiskers'. The tire has a thin, about 1/2 inch white wall line with the black side out. The build date of the car is October 1969 and the tire build date is September 1969. Is this tire not correct since it has the 'white line'? Appreciate any comments.
