Painting a 67 console - NCRS Discussion Boards
  • Craig G.
    • August 6, 2013
    • 9
    Striped the paint off the console and cleaned with MEK, took scotch bright to the surface to be painted .
    I'm painting with Acrylic Lacquer. Should I be concerned with any bonding issues?
  • Stephen L.
    • May 31, 1984
    • 3163
    Re: Painting a 67 console
    There is a product called "BULLDOG" that is an adhesion promoter that worked for me on some difficult parts. I believe I purchased it from PEPBOYS....
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Nasson etching compound.
      Comes in a spray can from O'Reilly's
      Good Stuff.
      Buy the way, TFP configuration left the little "V" grooves inside the outer edge mostly free of paint.
      Sometimes the template shifted slightly.
      A thin coat is best. Too thick an application will tend to fill-in the leather grain.
      Good Luck
      HaND
      • Craig G.
        • August 6, 2013
        • 9
        Thanks for everyones input
