Anyone know this car? - NCRS Discussion Boards
  • Robert M.
    • April 30, 1999
    • 415
    This car is for sale again and it looks quite nice and correct. When it was sold last year it appeared to be owned by Ken Chanpagne. I have been unable to contact him. I was just wondering if anyone in the New Jersely area knows anything about this LT1. Thans.
  • Larry M.
    • December 1, 1986
    • 541
    Re: Anyone know this car?
    That's a beautiful car; I love the color combo.
    It has the late-1970 dirstributor shielding (correct for his VIN) that matches '71; the driver-side valve cover should be reinstalled with the oil fill at the rear and the PCV at the front; not sure what's been done to the intake manifold to give it that almost-glossy appearance.
    Oh, and no, I don't know the car, but I'd love to take it for a drive.
    • Robert M.
      • April 30, 1999
      • 415
      You are right, the valve cover is on backwards, but didn't the PCV hose come from the front of the carb under the air cleaner?
      • Larry M.
        • December 1, 1986
        • 541
        That's my understanding; though I did see a '70 LT-1 once that had the PCV hose routed around the back of the carb before it made the (relatively) long run to connect to the valve in the forward-most valve cover hole. That installation appeared very awkward, and I doubt it was done that way at the factory.
        • Jeff P.
          • October 21, 2011
          • 287
          I don't think on a Holley Carburetor the PCV hose goes to the front. Quadrajet goes in the front.
            • 15641
            You are going to make me look, but I am pretty sure the LT1 PCV hose passes to the front of the carburator. Seems like a lot of folks want to route it through the engine lift hook on the driver's side front of the intake. An installation deduction for sure.
            • Jeff P.
              • October 21, 2011
              • 287
              Terry... Does the 90 degree molded hose end go to the carb or the pcv ?
                • 15641
                Working from memory = PCV end is molded for most 1970. If the car has NA9 or 1971> there is no molded end. The PCV for those later cars has a plastic T at the PCV and another hose goes to the carbon canister behind the driver's wheel house.
                • Larry M.
                  • December 1, 1986
                  • 541
                  Working from memory = The PCV for those later cars has a plastic T at the PCV and another hose goes to the carbon canister behind the driver's wheel house.
                  Yup; that's the setup on my '72.
                  • Robert M.
                    • April 30, 1999
                    • 415
                    Well this whole excercise is a moot point. I eviddently "wasted the sellers time" I guess I ask for too much information. He said he wouldn't sell it to me. Too bad it looks like a nice car and I am not a tire kicker, but a serious seller should be willing to provide certain information. The car is listed on Ebay. I won't put the seller on the spot by identifying him.
                    • Rey S.
                      • April 1, 1995
                      • 277
                      Painted or powder coated!
                      • Dan D.
                        • September 5, 2013
                        • 181
                        I'm an old man and I have been around the car business my whole life; both retail and wholesale. It's been my experience that when someone gets irritated because you ask questions about what they are trying to sell you; even though you may not know it, there is probably a very good reason why you shouldn't buy it.
                        • Robert M.
                          • April 30, 1999
                          • 415
                          The Ebay auction just ended. Based on the final bid, it makes me wonder that this car is not all it seems. I would have expected considerably more interest.
                          • William C.
                            • May 31, 1975
                            • 6037
                            Painted engine pad is not a comforting thing to see on a high $$ "Restoration" Also note the use of typical works like "numbers Matching" rather than "Original Engine". Just a couple of thoughts.
                            Bill Clupper #618
                            • Kenneth B.
                              • August 31, 1984
                              • 2091
                              I looked at mine Terry & you are right it passes to the front of the carb.
