C1 parking brake cable - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    i,m trying to take apart the parking brake tower. My problem is I can not figure out how to take the front cable from the tower. Would someone advise how to.
  • Terry D.
    • May 31, 1987
    • 2698
    Re: C1 parking brake cable
    Jerry Are you talking about the handle under the dash or the part under the car that splits to the rear wheels? Have you checked in the ST-12? It is usually pretty good at explaining how to take apart things. Terry
    • Donald H.
      • November 2, 2009
      • 2594
      If your talking about the cable and its attachment to the end of the handle at the firewall, in my 1960 AIM it is detailed in Section 5 (brakes) Sheet 6.00. There is a clip that you have to remove that holds the cable end to the large nut on the end of the brake handle. Then with the cable disconnected at the rear, pull the handle up until you can pull the cable out of the end of the groove in the handle.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • Jerry B.
        • August 31, 1994
        • 416
        Donald, any chance for a PM
        • Donald H.
          • November 2, 2009
          • 2594
          Jerry, sorry I didn't understand your post. I'll be happy to help
          Don Harris
