I have a problem with the anti-theft system on my early built (Sept) 73 coupe. It works correctly when opening the drivers door or the hood, but does nothing when the passenger door is opened. The door jamb switch works correctly and activates the courtesy lights.
The driver and hood switch have two connections, black and white. The passenger side has only the white. I have the AIM and Service manual and my wiring matches the service manual.
Has anyone had a similar issue and how did you correct it. The car is to be judged at Frisco (first time for flight judging for me and the car) and any thoughts or suggestions will be greatly appreciated.
The anti-theft horn is not an original but performs fine for the driver side and hood. The wiring diagram shows the anti-theft horn with a yellow wire attached too the body of the horn then attached to the body. Is this attachment too the body grounded?
George Walker
George Walker
