44-FF Spark Plugs NOT for Corvette - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I keep seeing someone on eBay trying to sell 44-FF spark plugs for your FI Corvette. However, these are NOT Corvette plugs, or at least Chevrolet Engineering didn't think so. See the attached scan from a 1962 Corvette News article.
    Caveat Emptor!
    Bob
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 44-FF Spark Plugs NOT for Corvette
    Bob,
    I think AC 44FF plugs were Corvair.
    • Jeffrey S.
      • May 31, 1988
      • 1882
      "FF" plugs are fully threaded with a 1/2" reach. They are Corvair plugs. Plain 44's are half threaded with a 3/8" reach. Do the math and beware. Of course, if it's on the internet it must be true.
      Jeff
      • Philip P.
        • February 28, 2011
        • 558
        I found this on the internet hope it true.
        ACDelco.Spark.Plug.Identification.Table
        Prefix and suffix letters are used to identify a specific type plus the numbers relate to thread size and heat range. For example, the R45TS spark plug shown is:
        R = Resistor
        4 = 14 mm Thread
        5 = Heat Range
        T = Taper Seat
        S = Extended Tip
        Plug Identification Table Prefix
        Identification Code Description
        B Series Gap
        C Commercial
        CS Chain Saw
        F Fine Line 14 mm 5/8″ Hex
        M Marine
        LM Lawn Mower type
        R Resistor
        S Shielded (5/8-24 thread)
        V Surface Gap
        Prefixes are sometimes combined e.g., VB, CR
        Numbering
        1st number denotes THREAD SIZE
        2nd number denotes HEAT RANGE
        Plug Identification Table Suffix
        A Cap Gap
        C Copper Core Center Electrode
        C Colder Version of M44 Plub
        E Special Design Electrode Extended Tip
        F 1/2″ (12.7 mm) reach
        FF 1/2″ (12.7 mm) reach, fully threaded
        G Pin Gap (cold-running)
        I Iridium Center Electrode
        J Boot Release Agent, Anti-Seize Compound
        K Special Design
        L Long Reach
        7/16″ (11.1 mm) reach, (14 mm) thread
        3/4″ (19 mm) reach, (18 mm) thread
        3/4″ (19 mm) reach, (14 mm) thread (fineline)
        LT Long reach, .715″ (18.16 mm), Tapered Seat
        M Special Design Electrode
        N 3/4″ (19 mm) reach, 3/8″ (9.5 mm) thread length
        R Resistor (Sport Vehicle Plugs)
        S Extended Tip
        S 7/8″ (22.3 mm) Moderate Long Reach
        23/32″ (18.25 mm)
        T Tapered Seat Shell Design
        TS Tapered Seat with extended tip
        XL Extra Long Reach, 3/4″ (19 mm) fully threaded
        Y 3-Prong Cloverleaf Electrode
        Z Special Gap (usually denotes wide gap)
        5 .050″ (1.3 mm) gap
        6 .060″ (1.5 mm) gap
        8 .080″ (2 mm) gap
        100 Iridium
        600 Resistor Type
        800 Platinum Type
        900 Double Platinum Type
        Suffixes are combined to form such AC suffix designations as FG, XLS, TS, FFM, TSX, SZ, etc.
        Phil
          • 15661
          Most plug manufacturer's numbering system can be used to decode the geometry and heat range, and you should be able to find this information in their online catalogs.
          The one exception that comes to mind is Autolite.
          A lot of guys talk about AC heat range as "44", "45"..., but as you can see from the breakdown, the first digit, in this case 4, means it's a standard 14MM, 3/8" reach with an 11/32" hex. The second number is the heat range, and in the case of AC the higher the heat range number, the hotter the plug. NGK and Champion conform to this convention, but Denso is just the opposite - a higher heat range number is colder.
          • Graeme B.
            • October 23, 2007
            • 213
            That's a small hex. Duke.
              • 15661
              To late to edit, so make that an [edit] 13/16" hex.
              • Michael H.
                • January 29, 2008
                • 7477
                To late to edit, so make that an 11/16" hex.
                How about 13/16"? You folks on the left coast have weird spark plugs.
                  • 15661
                  Yeah, that's the ticket! It's been so long since I used my 13/16" plug socket, I'm not even sure where it is.
                  • Page C.
                    • February 1, 1979
                    • 802
                    Also be aware of the repro AC44 & AC45 plugs in repro Delco boxes. Saw these at Corvette Carlisle this past August.
                    • John D.
                      • December 1, 1979
                      • 5507
                      Page, I didn't know there were repro AC spark plugs.
                      The AC 44FF plugs have been mislabeled on Ebay for many years now. Once I notified the seller but was ignored. John
                      • Dave S.
                        • August 31, 1992
                        • 2924
                        I saw those AC 44 and 45 reproduction spark plugs at Carlisle as well. For me its "never say never" just like distributor caps before this. I cannot believe someone would reproduce these AC plugs but I never thought anyone would reproduce Delco distributor caps either. It is apparent they did them without the permission of GM as there is no reference anywhere on the boxes. Only the red AC logo appears. In looking over both the boxes and plugs themselves the reproductions are easily detectable. Further the quality is likely to be very suspect. Rumor was they were looking for around $80/set which might work for the 44's but not for the 45's. At this time 44's can easily be found for $80 - $125/set and 45's can be found for $50/set all in NOS condition. The repros had 4 equal rings. Not very important as the wider green ring (if 3 equal and 1 unequal) is hidden by the spark plug boot.
                        • Bob B.
                          • March 1, 2003
                          • 831
                          John,
                          I also notified the seller and then I saw the plugs come up again and still advertised for Corvette. So, I sent another note and got a message that the seller had blocked me from sending messages to him! What does that tell you?
                          Bob
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Originally posted by Bob Baird (39424)
                            John,
                            Bob
                            Bob,
                            Would that be Tillyfour out of Rockford, IL? He claims that only the 1960 printing of the parts book shows the 44-FF plugs for Corvette. Here's a link.
                            Also, I tried to reply to your private message but your mailbox is full.
