Re 66 327 300HP Holley 4160
Gents,
The other day I noticed a pool of fuel on my intake manifold under the crankcase ventilation connection ( right rear) I assumed this was a leaking rear fuel bowl gasket. I went to my local flaps and got the Holley blue fuel bowl gaskets 108-92-2 and metering plate gaskets ( 108-89-2)
Now that I look at section 6M-47 of my Overhaul manual I see the 4160 has a different front and rear metering body. Is there a gasket for the secondary metering body? Looks like the bowl gaskets are correct but I will only need one metering plate gasket for the front. Correct or did I get the wrong gasket set.
BTW I have run the car again and I do not see any fuel leaking from the bottom of the float bowl.
Can the fuel bowl gaskets be installed with carb on car? I am apprehensive about damaging the threads on the fuel inlet and would rather not remove carb from car
Gents,
