427 rear cam journal - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    What changes were made in the rear cam bearing from the early cam with a groove to the later ungrooved cam?
    • 43279
    Re: 427 rear cam journal
    roger------
    The early big block (65-66) rear cam bearing was grooved around its inner circumference at the middle of the bearing. The later (67-74) was not grooved.
    • Roger G.
      • October 11, 2012
      • 268
      Thank you Joe!
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's the groove that Joe mentions (on the cam journal), and the corresponding groove and feeder hole and groove in the block bearing. In this case, the hole in the bearing is not perfectly lined up with the hole in the block.
        c
