Frame Slots 69 - NCRS Discussion Boards
Frame Slots 69
  • Roger G.
    • October 11, 2012
    • 268
    Frame Slots 69
    frame slot.jpgwhat is the purpose of these slots found on the frame in various locations? something to do with the manufacturing process?
  • Dick W.
    • 10483
    Re: Frame Slots 69
    Originally posted by roger gleason (55547)
    [ATTACH=CONFIG]48292[/ATTACH]what is the purpose of these slots found on the frame in various locations? something to do with the manufacturing process?
    That particular slot is for mounting the optional side pipes. Others are used for car carrier tie down, reference points, etc
    Dick Whittington
    • Mike E.
      • June 24, 2012
      • 920
      Re: Frame Slots 69
      The plate show below is welded in place via the slots. It reinforces the two piece main frame channel.
      Mike
      So installer/manufacturer could plug weld this piece. Plug welding is very common on such as frames
      • Timothy B.
        • April 30, 1983
        • 5196
        Re: Frame Slots 69
        Those holes are plug weld holes and the metal inside reinforcement shown above is for the jack area.
