67 inner heater box non ac - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    The inner heater box on 67 coupe is in real bad shape busted fiberglass both ends and busted studs ect. I think I want to replace this is a non jugged car. I see LIC has a complete box assy a bit pricy but an option. Any other suggestions or sources. Thanks Ed
  • Gary B.
    • February 1, 1997
    • 7080
    Re: 67 inner heater box non ac
    Ed,
    Original inner and outer C2 heater boxes do come up on e-bay every so often. Sometimes they need a bit of repair, say at the bolt holes, but some are in fairly decent shape to start with.
    Gary
    • Wayne W.
      • April 30, 1982
      • 3605
      These days with the vintage air being installed on so many, I would think there would be more available.
      • Michael H.
        • December 1, 1987
        • 733
        There are other suppliers out there not as expensive as LI. Check Dr.Rebuild and others as well.
        • Ed P.
          • July 31, 2002
          • 270
          I checked other venders but they are not listing complete box assy. I may have to call them. Most of the ones one that bay sight are really worse than mine. ed
          • Tom R.
            • December 20, 2010
            • 177
            I've seen the LIC heater assembly box in person and it is real nice. The hardware and fitment of the various pieces is outstanding. I wouldn't take a chance on the eBay stuff unless you can see lots of photos and close ups. This is a piece you don't want to reinstall after getting it in due to something not fitting. Try also the C1/C2 parts section on Corvette Forum.
            • Ed P.
              • July 31, 2002
              • 270
              Good someone has seen the LIC unit I am surprised they are the only ones so far I can find that carry this item remanned. Ed
              • Gerard F.
                • June 30, 2004
                • 3806
                Ed,
                If it is a non-judged car and you want to drive it in the summer, consider a Vintage Air AC system. With it, you will replace the heater box with something similar but not quite NCRS correct, for not much more.
                Did it on my 67/327/300, but saved the heater box for some purist beyond me. Drive to a lot of NCRS events in comfort, and the points deduct in judging is not that bad. Two top flights with it, but with a lot of credit for driving it.
                Jerry Fuccillo
